方案下载应用领域 | 制药/生物制药 |
检测样本 | 其他 |
检测项目 | 溶出物 |
参考标准 | - |
Quadrupole time-of-flight (Q-TOF) mass spectrometers are suitable for this purpose due to their high resolution and accurate mass measurement capabilities. An Agilent 1290 Infinity LC System and an Agilent 6540 Q-TOF system combined with statistical analysis software were used to detect and identify extractable and leachable (E&L) impurities from ophthalmic drug products.
Compounds leaching from container closure systems can cause contamination to drug substances or products. As part of a risk evaluation, it is necessary to identify these compounds and ensure that the drugs are suitable for their intended use. Typically, such compounds are present at low concentrations and are masked by the drug matrix. Therefore, highly sensitive and selective methods are required to detect and identify these compounds. Quadrupole time-of-flight (Q-TOF) mass spectrometers are suitable for this purpose due to their high resolution and accurate mass measurement capabilities. An Agilent 1290 Infinity LC System and an Agilent 6540 Q-TOF system combined with statistical analysis software were used to detect and identify extractable and leachable (E&L) impurities from ophthalmic drug products. Statistical data analysis was performed using Agilent Mass Profiler Software (MP) to determine the compounds present in the samples compared to controls. The database search tool within MP software helped to identify E&Ls using a customized accurate mass database. For the identification of unknown E&Ls, MS/MS data together with the structure prediction software, Molecular Structural Correlator, was used. In this study, 50 compounds were detected in each of the E&L samples.
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
