方案下载应用领域 | 制药/生物制药 |
检测样本 | 预防类生物药品 |
检测项目 | 含量测定>色谱法 |
参考标准 | / |
Using the Agilent 1290 Infinity II Bio LC System and Agilent AdvanceBio SEC 200 Å 1.9 μm PEEK-lined column in mAbs analysis
Size exclusion chromatography (SEC) of recombinant therapeutic proteins, such as monoclonal antibodies (mAbs), is an essential analytical tool to detect the presence of size variants, which may have adverse effects on safety and efficacy. SEC is commonly carried out using nonvolatile phosphate buffers, which makes the separation incompatible with mass spectrometry (MS). For this reason, a desalting step (online or offline) is required for peak identification.
The use of volatile MS-compatible buffers, such as ammonium acetate, has been demonstrated to be significantly less effective in comparison with phosphate buffers when applied on classic stainless-steel instrument/column configurations due to nonspecific interactions. The latter can be counteracted by using biologically inert or biocompatible flow paths. This application note demonstrates the potential of the combination of a polyether ether ketone (PEEK)-lined Agilent AdvanceBio SEC column with the Agilent 1290 Infinity II Bio LC System for native SEC/MS analysis of mAbs.
用于原辅料鉴定的 Agilent Cary 630 FTIR 光谱仪
分析洗手液中的醇类浓度
使用 Agilent Cary 630 ATR-FTIR 光谱仪测定婴儿米粉中的蔗糖浓度
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
