方案下载应用领域 | 食品/农产品 |
检测样本 | 小麦粉 |
检测项目 | 营养成分>锰, 钠, 铁, 镁, 铜, 钾 |
参考标准 | / |
Efficient elemental analysis of food samples
As more food products are imported and exported around the globe, greater quality control methods are needed. Some laboratories are looking for optimized systems that can efficiently and accurately analyze up to eight elements or more in as many as 100 samples per day. Such optimization is essential because it is inefficient to dedicate one analyst to manually running large numbers of samples every day.
Cu, Mn, Fe, K, Na, Mg, and Zn are seven elements most commonly measured in food testing. Flame atomic absorption spectrophotometry continues to be an appealing technique for this analysis due to its low purchase price, simple hardware and lower operational costs.
In this study, an Agilent AA 280FS flame atomic absorption spectrometer featuring Fast Sequential (FS) mode and PRecision Optimized Measurement Time (PROMT) was used to determine seven elements, Cu, Mn, Fe, K, Na, Mg, and Zn, in a wheat flour reference material.
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
