方案下载应用领域 | 环保 |
检测样本 | 环境水(除海水) |
检测项目 | 有机污染物>二噁英类化合物 |
参考标准 | / |
Abstract This application note illustrates a sensitive method used to analyze semivolatile organic compounds (SVOCs) on an Agilent 7000E triple quadrupole GC/MS system (GC/TQ). The use of GC/TQ instrumentation for analysis of SVOCs offers significant advantages. High selectivity afforded by multiple reaction monitoring (MRM) mode results in faster batch review and increased confidence due to the elimination of matrix interferences. These interferences are often present when using selective ion monitoring (SIM) or scan acquisition modes. Increased sensitivity can facilitate smaller extraction volumes that improve sustainability, reduce waste, and decrease costs associated with sample preparation, solvent usage, and waste disposal. A primary objective of this work was to demonstrate the ability of a GC/TQ to detect SVOCs at low levels to meet these laboratory needs while maintaining an excellent dynamic range.
Introduction
The analysis of SVOCs can be challenging as there is a wide variety of target analytes that include bases, neutrals, and acids. These analytes span a wide range of molecular weights and boiling points. The United States Environmental Protection Agency (US EPA) has issued regulations and guidelines in Method 8270E for the analysis of these analytes by GC/TQ. Typical samples that are analyzed for SVOCs include surface or ground water as well as solid samples. These samples are then extracted before analysis. If method sensitivity can be improved,
there is an opportunity to reduce sample and extract volumes that can result in decreased costs and increased lab sustainability. A preferable analytical method can also demonstrate a wide
dynamic range to reduce the need for sample dilution and reanalysis
单克隆抗体的高分离度、高通量体积 排阻色谱分析
采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
