Thin films and coatings (from a few nm to about 1 µm thick) need to be optimised both in the mechanical properties and tribological performance.Typically, this is done with a combination of indentation and scratch tests.Conventional scratch test conditions are not appropriate for these types ofmaterials as they were developed for testing thicker coatings. Instead thenano-scratch & wear module can provide what is needed. Figure 1: Ramped scratches to 500 mN show brittle fracture of 1.5 µm TiFeN films on Si at high load.
How it works
The sample to be tested is moved perpendicular to the scratch probe whilstthe contact is either held constant or ramped at a user-defined rate.Throughout the test the probe penetration depth and tangential (frictional)load are continuously monitored. Single and multi-pass tests are possible. Multi-pass tests allow the investigation of nano-wear and micro-wear.
The Nano-Scratch & Wear module has found many applications in sectorsas diverse as optical, microelectronics, polymer/biomaterial, and tribologicalcoatings. It is available as a stand alone instrument (nano-scratchtester) or as an option for the NanoTest Vantage platform.
Ramped scratch, corrected for baseline sampletopograp
Figure 2 shows a scratch test with 3 µm end radius probe scanning over a 150 µm track at a scan speed of 2 µm/s.
A pre-scratch scan was carried out using an ultra low contact force inorder to assess baseline sample topography.
The red line shows the on-load probe depth, which represents elastic and plastic depth. After 20 µm the load is ramped at 2.5 mN/s.
The black line shows the residual (plastic) depth once the scratch loadhas been removed. This has been corrected for initial sample topography.The frictional force on the indenter can be recorded throughout the experiment.
Micro-scratch Testing
The 30 N high load head can be used across the full load range formicro-scratch and micro-wear testing. The frictional force on the indenter canalso be recorded throughout the entire load range.
This high load scratch capability is available on NanoTest Vantage and NanoTest Xtreme instrumentsequipped with the high load head.
Check out our high temperature micro-scratch and impact testing tech note whichdescribes case studies that combine the proven NanoTest high temperaturecapability with micro-scale scratch and impact tests on hard, wear-resistantcoatings.
CooliBlade 热通道散热系统在电动交通方面的应用
2024 Neocera PLD用户网络研讨会(Webinar)第一轮通知
北京正通远恒科技有限公司将参加"第十八届全国MOCVD学术会议"
MML网络研讨会:多技术和多尺度纳米力学
铝离子检测仪 MIPS
氟离子检测仪 MIPS
内毒素检测仪 MIPS
农药检测仪 MIPS
石英晶体微天平 MIPS
纳米等离子体传感分析仪 S2
纳米等离子体传感分析仪 M8
全晶圆工业阴极荧光CL-SEM系统 Santis 300
皮秒时间分辨阴极荧光 CL-SEM系统 Chronos
磁场成像显微镜系统 Magma EFI HiRes
磁场成像显微镜系统 Magma EFI
多参数表面等离子体共振分析仪(分子互作分析仪) MP-SPR 410A
离子辅助脉冲激光沉积系统 Ion-Assisted PLD System
大尺寸脉冲激光沉积系统 Large-Area PLD Systems
组合型脉冲激光沉积系统 Combinatorial PLD System
