MML公司将参加2012美国材料学会的秋季展览(波士顿)
Micro Materials (MML)公司将于11月27-29日参加2012美国材料学会的秋季展览(波士顿),展台号:  1309 ,届时将推出很多创新的应用,热切欢迎您的光临。
New from Micro Materials at MRS Fall
Micro Materials is attending the 2012 MRS Fall Exhibit in Boston on 27th-29th November. Come to see us at Booth 1309 to find out more about our latest innovations.
Improvements to hot stage design
Test materials for extreme environments at operating temperatures up to 750oC
Improved isolation of heated elements
Faster stabilisation at elevated temperatures up to 750oC
New -20oC cold stage
Nanomechanical testing at temperatures down to -20oC
Integrated Peltier cooling of sample and indenter ensures isothermal contact
Simulated in service performance for materials for polar and atmospheric applications
New humidity control system
Nanomechanical testing in atmospheres from 10% - 90% RH
Rapid and accurate setting of target humidity
Invaluable for the examination of the mechanical behaviour of polymers, concretes and biomaterials
From the Apps Lab - Nano-fretting
The nano-fretting friction module has been used to determine failures due to high cycle wear of ta-C coatings.
The nano-fretting module is used to look at wear behaviour over tens of thousands of cycles, many more than a conventional nano-wear test.
This allows investigation of the wear of materials under very low contact pressures over a long duration.
Not attending MRS?
For more information visit our website at www.micromaterials.co.uk or contact us on info@micromaterials.co.uk
Seen the NanoTest on YouTube?
http://www.youtube.com/watch?v=WH4GcTjPyUI
http://www.youtube.com/watch?v=MGqPWSsuiRE
http://www.youtube.com/watch?v=5J6tLCf7A0c
阅读519次
最新动态
当前位置: 北京正通远恒 动态 MML公司将参加2012美国材料学会的秋季展览(波士顿)
