方案下载应用领域 | 环保 |
检测样本 | 环境水(除海水) |
检测项目 | 无机阴离子>其它 |
参考标准 | 0 |
The CMA provides enhanced productivity whereby all elements can be analyzed in one run, fulfilling all environmental detection limit requirements of the US-EPA. The CMA can be fitted to any model in the Jobin Yvon ICP product range very easily, allowing rapid and efficient analysis of hydride forming elements down to ultra trace levels. The CMA is very simple to set up and can be used as the standard sample introduction system. If a run does not require the use of hydride generation to reach ultra-trace levels, simply turn off the pump that transports the hydride generation reagents to the chamber.
拉曼+石墨烯+振动探测
拉曼+二维材料+应变工程
拉曼+CO2加氢反应+催化机理
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
