方案下载应用领域 | 建材/家具 |
检测样本 | 水泥/混凝土 |
检测项目 | |
参考标准 | 0 |
It is particularly interesting to point out that HORIBA Scientific ICPs have the ability to analyze any type of sample for example, cements, where there is a high salt content due to alkali fusion. The advantage of the ULTIMA 2C is to simultaneously measure the major and trace elements with very high precision. It also enables you to measure an internal standard at the same time and with the same optics for all major elements, improving the repeatability and accuracy for these elements. The use of the sheath gas device originally patented by JY, enables analysis without clogging of the injector tube and to be able to run samples up to 300 g/L salt content. Given the above criteria, ICP emission spectrometry is suitable for analysis of the major and minor elements in cement.
荧光光谱+蛋白质检测+荧光特性
荧光光谱+智能形致变色荧光材料+荧光特性
荧光光谱+荧光探针+精准医疗
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
