方案下载应用领域 | 电子/电气 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 0 |
Birch, et al., have shown that fluorescence anisotropy-decay in sols with two rotational correlation times can be explained by the existence of silica particles. This interpretation allows monitoring sol-gels in situ with sub-nanometer resolution. Because a fluorophore immobilized in a gel does not de- polarize fluorescence, one can study particle size well after the sol-to-gel transition time, a major advantage over scattering techniques (e.g., with neutrons or X-rays) where gel-scattering distorts the scattering function. Moreover, the rapid data-acquisition needed to acquire anisotropy-decay data within time-spans as short as a few minutes is aided greatly by the high-repetition rate of the NanoLED excitation sources from HORIBA Jobin Yvon.
荧光光谱+蛋白质检测+荧光特性
荧光光谱+智能形致变色荧光材料+荧光特性
荧光光谱+荧光探针+精准医疗
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
