方案下载应用领域 | 造纸/印刷/包装 |
检测样本 | 造纸 |
检测项目 | |
参考标准 | 0 |
A number of additives are used in papermaking, from calcium carbonate used as a filler to a variety of minerals and latex added to the surface coating to improve brightness, gloss and printability. The selection of the additive depends on the surface finish required and the final use of the paper. Colored papers require the addition of a pigmenting agent. The particle size of all these materials affects surface finish, color strength, and mechanical properties. Smaller particle size provides a smoother surface and better coverage per unit of additive.
荧光光谱+蛋白质检测+荧光特性
荧光光谱+智能形致变色荧光材料+荧光特性
荧光光谱+荧光探针+精准医疗
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
