用ICP光谱法分析水泥中的主量元素Ca
2017/12/18   下载量: 7
方案下载
应用领域 建材/家具
检测样本 水泥/混凝土
检测项目
参考标准 0
It is particularly interesting to point out that HORIBA Scientific ICPs have the ability to analyze any type of sample for example, cements, where there is a high salt content due to alkali fusion. The advantage of the ULTIMA 2C is to simultaneously measure the major and trace elements with very high precision. It also enables you to measure an internal standard at the same time and with the same optics for all major elements, improving the repeatability and accuracy for these elements. The use of the sheath gas device originally patented by JY, enables analysis without clogging of the injector tube and to be able to run samples up to 300 g/L salt content. Given the above criteria, ICP emission spectrometry is suitable for analysis of the major and minor elements in cement.
方案下载
配置单
方案详情
上一篇 荧光光谱+有机掺杂材料+构建
下一篇 用ICP光谱法分析水泥中的主量元素As
文献贡献者
HORIBA(中国)
白金会员第22年
查看全部资料
相关方案
当前位置: HORIBA 方案 用ICP光谱法分析水泥中的主量元素Ca
