高性能ICP光谱仪在润滑油分析中的应用方案Ag
2017/12/18   下载量: 2
方案下载
应用领域 石油/化工
检测样本 润滑油
检测项目 含量分析>微量元素
参考标准 0
Because the aim of the analysis lubricating oils is to monitor the oil of an engine and get a trend analysis over time, the best accuracy is not required. The trend analysis allows the analyst to see that the oil is changing and when the engine needs stripping down before a catastrophic failure. The use of the internal standard is not required because the results are only compared to previous results. The procedure is thus very simple: new two point calibration each time the sample is analyzed and dilution of the samples by 1:5, 1:10 or 1:100, depending on the viscosity of the oil samples and whether lower detection limits are required.
方案下载
配置单
方案详情
上一篇 荧光光谱+有机掺杂材料+构建
下一篇 高性能ICP光谱仪在润滑油分析中的应用方案B
文献贡献者
HORIBA(中国)
白金会员第22年
查看全部资料
相关方案
当前位置: HORIBA 方案 高性能ICP光谱仪在润滑油分析中的应用方案Ag
