用顺序型ICP—AES分析玻璃中的主要元素Mg
2017/12/21   下载量: 1
方案下载
应用领域 建材/家具
检测样本 建筑玻璃
检测项目
参考标准 0
The relatively clean spectrum of glass constituents enables the use of the JY 2000-2 without the need of the high resolution of the ULTIMA 2. The results show excellent agreement with expected results for all element, both major constituents and traces. The use of sequential internal standard has been shown to compensate for any viscosity differences between the samples and standards. The speed of analysis of less than 2 minutes for the 10 elements determined, and the detection limits achieved, are more than adequate for laboratories doing ordinary glass analysis. Although both acid and fusion methods were tried, afusion would appear to fulfil the requirements of full analysis in one sample preparation. If lower detection limits are required for some of the trace elements, then an HF acid digestion will be required as well.
方案下载
配置单
方案详情
上一篇 荧光光谱+有机掺杂材料+构建
下一篇 用顺序型ICP—AES分析玻璃中的主要元素Li
文献贡献者
HORIBA(中国)
白金会员第22年
查看全部资料
相关方案
当前位置: HORIBA 方案 用顺序型ICP—AES分析玻璃中的主要元素Mg
