采用发射光谱法测定铋中钒含量
2017/12/25   下载量: 6
方案下载
应用领域 钢铁/金属
检测样本
检测项目
参考标准
The analysis of organometallics samples using an ICP-OES is not a simple proposition as digestion of the sample or dissolution in an adequate solvent is required. Digestion is a lengthy process and loss of analytes and contamination are severe problems. The dissolution method however requires an aromatic solvent, resulting in specific analysis conditions and special pump tubing, which are not easy problems for a typical laboratory to overcome. This Application Note presents the preparation,characterization and optimization of bitumen after emulsion in water.
方案下载
配置单
上一篇 荧光光谱+蛋白质检测+荧光特性
下一篇 采用发射光谱法测定铋中镍含量
文献贡献者
HORIBA(中国)
白金会员第22年
查看全部资料
相关方案
当前位置: HORIBA 方案 采用发射光谱法测定铋中钒含量
