RCT basic safety control --- IKA最畅销实验室产品
作者: 德国IKA 集团Ms. Sabine Freund
新型加热磁力搅拌器,带安全温度控制, 可以实现无人操作。 RCT BASIC,来自IKA 的经时间鉴证的最畅销实验室产品,现在又多了一项功能, 即:具有可调式安全回路, 可调安全温度范围为 50 – 380°C.
该搅拌器具有符合DIN 12878的连接端口, 可连接接触式电子模糊温度计, 如ETS D4.
新型搅拌器加强了加热控制功能, 以确保安全第一。 IP 保护等级为42, 使用寿命长。
加热盘直径 135MM, 用高抛光度的高硅铝合金制成, 以保证最大的热传递率。 热输出功率为600W.
强磁力粘附, 以免搅拌子破裂。
该仪器有H99 保护罩可供选择, 保证机身清洁。 搅拌量为20升(水)。
可联系我们IKA以获得更详细资料:
IKA WORKS GUANGZHOU
Tel: 0086-20-82226772
Fax: 0086-20-82226776
E-mail: sales@ikagz.com.cn
www.ika.net
RCT basic safety control: a best-seller for your laboratory
Safety magnetic stirrer with heating, suitable for unsupervised operation. This long-established laboratory best-seller from IKA® now features an adjustable safety circuit for the heating plate temperature for the range: 50 – 380°C.
This stirrer has a DIN 12878 bush for connection to an electronic contact thermometer such as the ETS D 4 fuzzy.
The new version incorporates improved heating control to guarantee top class safety. The fully enclosed design with a IP 42 rating guarantees a long service life.
The heating plate (diameter 135 mm) is made from highly polished Silumin to ensure optimum heat transfer. Heat output is 600 W.
The high magnetic adhesion prevents rapid cracking of the magnetic bars.
The stirrer is supplied complete with an H 99 protection cover. Stirring quantity (H20) for this unit is 20 litres.
For more information, contact:
IKA®-Werke GmbH & Co.KG
79219 Staufen, Germany
Tel.: +49 7633 831-0
Fax: +49 7633 831-98
e-mail: sales@ika.de
www.ika.de
阅读2491次
已关注
