供应UVTest®荧光/紫外老化试验箱40瓦紫外荧光灯管 (UVA-340, UVB-313, UVA-351)
Atlas的UVTest是一种用于荧光紫外和冷凝老化测试方法的经济实惠型紫外老化试验箱。该仪器将UVA-340、UVB-313或UVA-351紫外灯管用于各种用途。触摸屏提供了几种语言的简单操作和控制。它拥有获得专*利的辐照端口,用于安*全校准,这是荧光紫外老化测试领域的其他竞品所不具备的。可将两个测试单元堆叠在一起,以节省空间,并且可以使用循环喷淋选项减少去离子水的使用量。
标准-
ASTM D4329
Standard Practice for Fluorescent UV Exposure of Plastics
ASTM D4587
Standard Practice for Fluorescent UV-Condensation Exposures of Paint and Related Coatings
ASTM D4799
Standard Test Method for Accelerated Weathering Test Conditions and Procedures for Bituminous Materials (Fluorescent UV and Condensation Method)
ASTM D5208
Standard Practice for Operating Fluorescent Ultraviolet (UV) and Condensation Apparatus for Exposure of Photodegradable Plastics
ASTM G151
Standard Practice for Exposing Nonmetallic Materials in Accelerated Test Devices that Use Laboratory Light Sources
ASTM G154
Standard Practice for Operating Fluorescent Light Apparatus for UV Exposure of Nonmetallic Materials
DIN EN 12224
Geotextiles and geotextile-related products - Determination of the resistance to weathering
DIN EN 1297
Flexible sheets for waterproofing - Bitumen, plastic, and rubber sheets for roofing - Method of artificial ageing by long term exposure to the combination of UV-radiation, elevated temperature and water
DIN EN 13523-10
Coil coated metals - Test methods - Part 10: Resistance to fluorescent UV light and water condensation
DIN EN ISO 4892-1
Plastics - Methods of exposure to laboratory light sources - Part 1: General guidance
EN 927-6
Paints and varnishes - Coating materials and coating systems for exterior wood - Part 6: Exposure of wood coatings to artificial weathering using fluorescent UV and water
ISO 11997-2
Paints and varnishes - Determination of resistance to cyclic corrosion conditions - Part 2: Wet (salt fog)/dry/humidity/UV light
ISO 16474-3
Paints and varnishes - Methods of exposure to laboratory light sources - Part 3: Fluorescent UV lamps
ISO 4892-3
Plastics - Methods of exposure to laboratory light sources - Part 3: Fluorescent UV-lamps
prEN 1062-4
Paints and varnishes - Coating materials and coating systems for exterior masonry - Part 4: Preconditioning of exterior coatings to UV radiation and water in apparatus
SAE J2020
Accelerated Exposure of Automotive Exterior Materials Using a Fluorescent UV and Condensation Apparatus
电动车零部件可靠度测试解决方案
LED路灯试验规范
LCD显示器试验规范
智慧手表可靠度试验条件
