方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
6、Technical data Specifications for LX series ModelParameters LX-300 LX-600 LX-1000 Temperature range@25℃ 0~40℃ 0~40℃ 0~40℃ Temperature Stability ±0.1℃ ±0.2℃ ±0.2℃ Cooling Capacity@20℃ 300W 600W 1000W Pump pressure 0.6 / 4bar 4bar 4bar Pump Flow Rate 15 L / min 6 L/min 7 L/min Working mode Continuous Continuous Continuous Filling Port mm Ø25 Ø25 Ø25 Reservoir Capacity 4.5 L 8 L 8 L Dimensions mm 235W×475D×490H 325W×620D×550H 325W×620D×550H Power Volts Hz Amps AC220V,50Hz,10A AC220V,50Hz,10A AC220V,50Hz,10A Shipping Weight kg 23 31 35
油封真空泵抽除水蒸汽问题的解决
-100℃超低温气流方案
公斤,Mpa,牛顿,PSI,标准大气压的相互换算
