资料下载Introduction Particle image velocimetry (PIV) has proven its strength as a flow diagnostic tool to characterise instantaneous velocity fields and derived quantities such as vorticity. Recent efforts apply momentum conservation principles on planar velocity data in order to extract more quantities, such as pressure fields and integral aerodynamic forces. The theoretical concepts for this 憄lanar pressure imaging? (PPI) have been established and its practical implementation for steady (or time-averaged) flows under approximately 2D flow conditions has been demonstrated (e.g. Baur and K鰊geter 1999, Gurka et al. 1999, Oudheusden et al. 2007). The next challenge is to extend PPI to unsteady flows. This extension can be done on basis of time-resolved flow diagnostics such as time-resolved PIV (TR-PIV), cf. Kurtulus et al. 2007. Instantaneous pressure fields are particularly interesting in bluff-body flows and in fluid-structure interactions, both are important in e.g. wind-engineering applications. A serious complication in extending the planar approach is that flows tend to develop 3D instantaneous structures even for nominally 2D configurations, especially at larger Reynolds numbers.
层析PIV
简介:湍流本质上具有三维(3D)立体结构属性。普通的二维(2D)包 括采用激光照明的成像测量无法在所有三个空间维度上分辨湍流 的结构。而利用多视角成像信息,采用层析重构技术则可以在三 个空间维度上同时捕捉记录复杂流动的瞬态结构。应用针对体像 素的三维(3D)相关处理技术,可以由时间相关的体成像数据计 算出瞬态三维空间的流场。 LaVision功能强大的,基于层析粒子成像测速(Tomo-PIV)和层 析粒子跟踪测速(Tomo-PTV)技术的FlowMaster激光成像系统, 能够以极高的空间分辨率记录强湍流,火焰以及喷雾对象的瞬态 体视流场。
利用2维粒子成像测速技术研究鲨鱼自由游动的水动力学推动机制用于优化水中船舶的推进特性
简介:Two-dimensional velocity fields around a freely swimming freshwater black shark fish in longitudinal (XZ) plane and transverse (YZ) plane are measured using digital particle image velocimetry (DPIV). By transferring momentum to the fluid, fishes generate thrust. Thrust is generated not only by its caudal fin, but also using pectoral and anal fins, the contribution of which depends on the fish’s morphology and swimming movements. These fins also act as roll and pitch stabilizers for the swimming fish. In this paper, studies are performed on the flow induced by fins of freely swimming undulatory carangiform swimming fish (freshwater black shark, L = 26 cm) by an experimental hydrodynamic approach based on quantitative flow visualization technique. We used 2D PIV to visualize water flow pattern in the wake of the caudal, pectoral and anal fins of swimming fish at a speed of 0.5–1.5 times of body length per second.
气体自由喷射的单次体视3维层析激光诱导荧光成像研究
简介:Single-shot, tomographic imaging of the three-dimensional concentration field is demonstrated in a turbulent gaseous free jet in co-flow using volumetrically illuminated laser-induced fluorescence. The fourthharmonic output of an Nd:YAG laser at 266 nm is formed into a collimated 15 × 20 mm2 beam to excite the ground singlet state of acetone seeded into the central jet. Subsequent fluorescence is collected along eight lines of sight for tomographic reconstruction using a combination of stereoscopes optically coupled to four two-stage intensified CMOS cameras. The performance of the imaging system is evaluated and shown to be sufficient for recording instantaneous three-dimensional features with high signal-tonoise (130:1) and nominal spatial resolution of 0.6–1.5 mm at x/D = 7–15.5.
游动的未成熟海胆幼虫的个体发育变化和湍流中的取向
简介:Many marine organisms have complex life histories, having sessile adults and relying on the planktonic larvae for dispersal. Larvae swim and disperse in a complex fluid environment and the effect of ambient flow on larval behavior could in turn impact their survival and transport. However, to date, most studies on larvae–flow interactions have focused on competent larvae near settlement. We examined the importance of flow on early larval stages by studying how local flow and ontogeny influence swimming behavior in pre-competent larval sea urchins, Arbacia punctulata. We exposed larval urchins to grid-stirred turbulence and recorded their behavior at two stages (4- and 6-armed plutei) in three turbulence regimes. Using particle image velocimetry to quantify and subtract local flow, we tested the hypothesis that larvae respond to turbulence by increasing swimming speed, and that the increase varies with ontogeny.
落到倾斜箔片上的液体薄膜流动的时间空间分辨热传导过程的实验研究
简介:This paper describes the development of an experimental technique that combines simultaneous planar laser-induced fluorescence (PLIF) and infrared (IR) thermography imaging, and its application to the measurement of unsteady and conjugate heat-transfer in harmonically forced, thin liquid-film flows falling under the action of gravity over an inclined electrically heated-foil substrate. Quantitative, spatiotemporally resolved and simultaneously conducted measurements are reported of the film thickness, film free-surface temperature, solid–liquid substrate interface temperature, and local/instantaneous heat flux exchanged with the heated substrate. Based on this information, local and instantaneous heat-transfer coefficients (HTCs) are recovered. Results concerning the local and instantaneous HTC and how this is correlated with the local and instantaneous film thickness suggest considerable heat-transfer enhancement relative to steady-flow predictions in the thinner film regions.
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
