方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The aim of this work was to understand the physical requirements as well as to develop methodology required to employ Time Resolved Digital Particle Image Velocimetry (TRDPIV) for measuring high speed, high magnification, near wall flow fields. Previous attempts to perform measurements such as this have been unsuccessful because of both limitations in equipment as well as proper methodology for processing of the data. This work addresses those issues and successfully demonstrates a test inside of a transonic turbine cascade as well as a high speed high magnification wall jet. From previous studies it was established that flow tracer delivery is not a trivial task in a high speed high back pressure environment. Any TRDPIV measurement requires uniform spatial seeding density, but time-resolved measurements require uniform temporal seeding density as well. To this end, a high pressure particle generator was developed. This advancement enhanced current capability beyond what was previously attainable. Unfortunately, this was not sufficient to resolve the issue of seeding all together, and an advanced data reconstruction methodology was developed to reconstruct areas of the flow field that where lost do to inhomogeneous seeding. This reconstruction methodology, based on Proper Orthogonal Decomposition (POD), has been shown to produce errors in corrected velocities below tradition spatial techniques alone. The combination of both particle generator and reconstruction methodology was instrumental for successfully acquiring TRDPIV measurements in a high speed high pressure environment such as a transonic wind tunnel facility. This work also investigates the development of a turbulent wall jet.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
