方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Hydrogen/air and methane/air flames in axi-symmetric opposed jet burners were investigated experimentally for different flow velocities, burner geometries and fuel dilutions. Above critical strain rate values there is the local extinction of the planar diffusion flame, and the edge flame forms, which propagates and stabilizes further away from the axis of symmetry, assuming a toroidal shape. The ranges of air and fuel flow velocities over which the diffusion or the edge flame are stable were determined. There is a substantial range over which both flames can be stabilized, and the transition between the two flame types exhibits a strong hysteresis. Raman spectroscopy was used for the determination of the spatial distribution of temperature and major species concentrations, while the OH radical distribution was obtained with Planar Laser Induced Fluorescence (LIF). Particle Image Velocimetry (PIV) was employed to characterize the flow fields both in cold and reactive conditions.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
