方案下载应用领域 | 环保 |
检测样本 | 空气 |
检测项目 | 其他>其它 |
参考标准 | 暂无 |
Low-rise buildings located in the urban areas are generally surrounded by buildings of similar size. The interference of surrounding buildings has been found to be significant on wind loads in straight-line winds. In this study, systematic experiments of tornado-induced wind loads and flow patterns around a typical low-rise gable-roof building with different layouts of surrounding buildings were carried out in a laboratory. Effects of spacing, height ratios of the surrounding buildings to the test building and specific building orientations were considered. The results indicate that the reduction of the horizontal load is caused by sheltering effect from the surrounding buildings. The uplift load, however, could increase or decrease dependent on building orientation, layout and the type of the surrounding buildings. The complicated flow patterns around the test building are discussed and correlated to the wind loads. This study would improve the understanding of tornado-induced loads on a low-rise gable-roof building
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
