方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Dual particle image velocimetry (dual PIV) measurements have been performed to investigate the space–time correlations in two subsonic isothermal round jets at Mach numbers of 0.6 and 0.9. The correlation scales are analyzed along the centerline and in the shear-layer center over the first 11 jet diameters from the nozzle exit. To provide robust results over a wide range of flow conditions, these correlation scales are given in terms of their appropriate quantities, namely, the mean or rms velocity in reference to velocity and the momentum thickness or the half-velocity diameter in reference to length in the shear layer and on the jet axis, respectively. From these results, a discussion on the modeling of turbulence in jets is addressed. The self-similarity of some space correlation functions in the shear layer and on the jet axis is shown. Furthermore, far enough downstream in the shear layer, some of the ratios between the space and time scales are relatively close to the values expected in homogeneous and isotropic turbulence. It is also found that the ratio between the integral length and the time scales in the fixed frame is of the order of the local mean flow velocity. In the convected frame, the appropriate scaling factor is the rms velocity.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
