方案下载应用领域 | 医疗/卫生 |
检测样本 | 全血/血清/血浆 |
检测项目 | |
参考标准 | 暂无 |
Over the past 15 years, coil embolization has emerged as an effective treatment option for cerebral aneurysms that is far less invasive than the long-standing convention of surgical clipping. However, aneurysm recurrence after coil embolization is not uncommon: recurrence rates as high as 50% have been reported in the literature. One factor that may contribute to recurrence after coiling is residual flow into the aneurysmal sac. At present, there is limited quantitative knowledge of the relationship between coil packing density and aneurysmal inflow. We present an in vitro fluid dynamic study of basilar tip aneurysm models that elucidates this relationship. At physiologically normal flow rates, we found that a packing density of 28.4% decreased aneurysmal inflow by 31.6% in a wide-neck model, and that a packing density of 36.5% decreased aneurysmal inflow by 49.6% in a narrow-neck model. Results also indicated that coiling reduced aneurysmal inflow more significantly at lower parent vessel flow rates, and that coiling reduced neck-plane velocity magnitudes more significantly for narrow-neck aneurysms. Our study provides novel quantitative information that could ultimately contribute to improved outcomes for patients with cerebral aneurysms by enabling more effective coil embolization.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
