方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Geostrophic adjustment of an isolated axisymmetric lens was examined to better understand the dependence of radial displacements and the adjusted velocity on Burger number and the geometry of initial conditions. The behavior of the adjustment was examined using laboratory experiments and numerical simulations, which were in turn compared to published analytical solutions. Three defining length scales of the initial conditions were used to distinguish between various asymptotic behaviors for large and small Burger number: the Rossby radius of deformation, the horizontal length scale of the initial density defect, and the horizontal length scale of the initial pressure gradient. Numerical simulations for the fully nonlinear time dependent adjustment agreed both qualitatively and quantitatively with analogous analytical solutions. For large Burger number, similar agreement was found in laboratory experiments. Results show that a broad range of final states can result from different initial geometries, depending on the values of the relevant length scales, and the Burger number computed from initial conditions. For Burger number much larger or smaller than unity, differences between different initial geometries can readily exceed an order of magnitude for both displacement and velocity.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
