方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
In this study, four different volume reconstruction techniques for tomographic PIV are investigated using synthetic and experimental data at different particle densities. Multiplied line of sight (MLOS) and Minimum line of sight (MinLOS) represent methods that need significant less computation time than the standard MART reconstruction. Motion Tracking Enhancement (MTE) on the other hand needs significant more computational time, but has the potential to achieve more accurate results especially at higher seeding densities. The presented results confirm that the fast MLOS and MinLOS reconstruction are applicable at low seeding densities of about 0.02 particles per pixel (ppp), and achieve a lower accuracy than standard MART. MTE on the other hand is proven to be applicable in the broadest density range from 0.01 ppp up to 0.2 ppp.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
