方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Measurements and simulations are presented of the flow past a tailplane research airfoil which is designed to show a mixed leading-edge trailing-edge stall behaviour. The numerical simulations were carried out with two flow solvers that introduce transition prediction based on linear stability theory to RANS simulations for cases involving laminar separation bubbles. One of the methods computes transition locations across laminar separation bubbles whereas the other assumes transition onset where laminar separations occur. For validation of the numerical methods an extensive measurement campaign has been carried out. It is shown, that the methodology mentioned first can simulate the size of laminar separation bubbles for angles of attack up to where the separation bubble and the turbulent separation at the trailing edge are well behaved and steady in the mean. With trailing edge separation involved, the success of the new numerical procedure relies on the diligent choice of a turbulence model. Finally, for flows with increased unsteady behaviour of both, separation bubble and turbulent separation, which were observed at higher angles of attack in the experiment between maximum lift and leading-edge stall, steady state prediction methods for transition can no longer be applied and time-accurate methods have to be developed in a further step.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
