方案下载应用领域 | 汽车及零部件 |
检测样本 | 整车安全 |
检测项目 | 主动安全>速度探测 |
参考标准 | 暂无 |
The current direction for Diesel combustion system development is towards homogenization, in order to reduce particulate and NOx emissions. However, a strong increase of carbon monoxide emissions (CO) is frequently noted in combination with enhanced homogenization. Therefore, the current investigation focuses on a detailed analysis of the particulate - CO trade-off using a laser-optical and multidimensional CFD investigation of the combustion process of a swirl HSDI system. The CFD methodology involves reduced kinetics for soot formation and oxidation and a three-step CO model. These models are validated by a detailed comparison to optical measurements of flow, spray penetration and the spatial distribution of soot, temperature and oxygen concentration. The results obtained show that high concentrations of CO occur as an intermediate combustion reaction product. Subsequently, CO and soot are oxidized in large areas of the combustion chamber. In part load operation, CO emissions are mainly caused by dilution effects in the early phases of combustion. However, the engine’s soot emissions are caused by insufficient oxidization. Soot generation and oxidation are found to be strongly impacted by the slight non-homogeneity of the swirl motion. The gaseous emissions are not affected by the small differences in local flow, which are outlined further in the text.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
