缝槽气膜冷却流动特性的最小介入扰动诊断的实验研究
2011/04/25   下载量: 3
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
The performance of a propulsion system is directly proportional to its operating temperature; therefore, an optimum operation regime will undoubtedly generate intense thermal loads on system components. If the system is designed for reusability and/or long range missions, it may be necessary to perform active cooling of critical components to prevent premature failure of the system. One such method is film cooling, in which a layer of relatively cool gas is injected near the surface to be protected. This work describes the use of minimally intrusive diagnostics to characterize the kinematics, thermal dynamics and heat transfer of slot film cooling flows over a wide range of blowing ratios, generating a comprehensive database for detailed analysis, as well as for further use by model developers.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 湍动稳定环形分层火焰特性的实验研究
文献贡献者
相关方案
当前位置: 欧兰科技 方案 缝槽气膜冷却流动特性的最小介入扰动诊断的实验研究
