方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Within the framework of an investigation into valve operating strategies for homogeneous charge direct injection spark ignition engines under part load conditions this paper discusses the in-cylinder flow fields developed by running an optical engine with an early inlet valve closing strategy with a lift of 3.9 mm that produces 3bar IMEP at 3500 rpm under firing conditions. The experimental facilities are similar to previous work but measurement technique has been optimized with the significant aspect of this work being that the flow fields were determined in three vertical planes and one horizontal plane to highlight the three dimensional and the highly cyclic nature of the flow. These characteristics have significant impact on the application of the PIV technique and data processing to ensure a high degree of confidence in the flow fields generated. The time varying nature of this three dimensional flow field is discussed and how it impacts on the PIV measurement technique particularly as regards data acquisition and data processing. The true extent of the complex three dimensional flow field is readily seen and that, even though the combustion chamber geometry is symmetrical, the swirl flow field is not. The main features of the vertical flow structure are described over a crankangle period from 90oCA to 120oCA which highlight the dominant feature as being a wall jet flow which interacts with the piston crown to generate a strong reverse tumble flow.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
