方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
This work presents preliminary results of flow separation control from the flap of a high-lift airfoil using a single dielectric barrier discharge (DBD) plasma actuator. Control effectiveness is investigated for two actuator locations as well as various reduced frequencies, applied voltages and waveforms. Results show that a single DBD plasma actuator located at the flap shoulder can slightly increase or reduce the size of the time-averaged separation bubble over the flap depending on the frequency of actuation. This effectiveness is not improved by an increase in applied voltage or a change from a sinusoidal to positive sawtooth waveform for the cases examined. Spatial eigenmodes calculated from twocomponent PIV using POD show that a single DBD plasma actuator at the flap shoulder can have a significant effect on the structure of higher order modes. However the corresponding energy of these modes is low in comparison to the dominant modes in the wake. Nomenclature Cp =
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
