高水平等离子体能量耦合预混火焰中氮氧化物生成
2011/06/19   下载量: 2
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
This paper presents quantitative planar laserinduced fluorescence (PLIF) imaging of nitric oxide (NO) in a transient-arc direct-current plasmatron igniter using premixed air/fuel mixtures. Quantitative measurements of NO are reported as a function of gas flow rate (20–50 standard cubic feet per hour), plasma power (100–900 mA, 150–750 W), and equivalence ratio (0.7–1.3). Images were corrected for temperature effects by using 2-D temperature field measurements obtained with infrared thermometry and calibrated by a more accurate multiline fitting technique. The signals were then quantified using an NO addition method and spectroscopic laser-induced fluorescence modeling of NO. NO PLIF images and single-point NO concentrations are presented for both plasma-discharge-only and methane/air plasma-enhanced combustion cases. NO formation occurs predominantly through N2(v) + O → NO + N for the plasmadischarge- only case without combustion. The NO concentration for the plasma-enhanced combustion case (500–3500 ppm) was an order of magnitude less than the plasma-discharge-only case (8000–15 000 ppm) due to the reduction of plasma reactions by the methane. Experiments show the linear decay of NO from equivalence ratio 0.8–1.2 under the same flow condition and discharge current. Index Terms—Nitric oxide (NO), plasma torch, plasma-assisted combustion.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 叶片电极诱导电流体力学羽流的数值模拟和PIV实验研究
文献贡献者
相关方案
当前位置: 欧兰科技 方案 高水平等离子体能量耦合预混火焰中氮氧化物生成
