方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Active flow control of jets with Localized Arc Filament Plasma Actuators (LAFPAs) is conducted over a wide range of the fully expanded jet Mach numbers (MJ or simply jet Mach number). The jet Mach numbers covered in the present research are 0.9 (with a converging nozzle), 1.2 (overexpanded), 1.3 (perfectly expanded), and 1.4 (underexpanded) with a design Mach number 1.3. Additionally, limited experiments are carried out for an MJ = 1.65 perfectly-expanded jet. The exit diameter is 2.54 cm (1 inch) for all cases and eight LAFPAs are equally distributed on the perimeter of a boron nitride nozzle extension. The jet spreading is strongly dependent on duty cycle, forcing frequency, and azimuthal modes. The performance of LAFPAs for jet spreading is investigated using two-dimensional particle image velocimetry (PIV). There is an optimum duty cycle, producing maximum jet spreading, for each forcing frequency. A relationship between the optimum duty cycle and forcing frequency is determined from the extensive results in the MJ 0.9, and this relation is used for all experiments. The effect of forcing frequency is investigated for a wide range of forcing Strouhal numbers (StDF = fFD/Ue, where fF, D, and Ue, are forcing frequency, nozzle exit diameter, and jet exit velocity respectively), ranging from 0.09 to 3.0. The azimuthal modes (m) investigated are m = 0 – 3, ±1, ±2, and ±4 - this comprises all modes available with eight actuators. The performance of LAFPAs does also strongly depend on the stagnation temperature of the jet and MJ. The effects of stagnation temperature are investigated for 1.0, 1.4, and 2.0 times the ambient temperature in MJ 0.9 jet for very limited azimuthal modes and StDF. In an MJ 1.65 perfectly-expanded jet, the control authority of LAFPAs is investigated for only m = ±1 and StDF ∼ 0.3.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
