约束流体3C-2D 速度场的数字高速全息测量
2012/01/14   下载量: 8
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
In the last years, several techniques have been developed and improved in such a way that it is possible to measure the three velocity components in a flow. Some techniques as Stereoscopic PIV or holographic PIV are well known. Others, like tomographic PIV started to develop more recently. Stereoscopic Particle Image Velocimetry (SPIV) or Tomographic PIV need a complex set-up, involving flow visualization with several cameras, and present important restrictions when applied to confined liquid flows. Others like Holographic PIV cannot be applied in flows with a high particle density. Here a new technique, called High Speed Digital Image Plane Holography has been developed for the measurement of the three velocity components in a complex geometry brain aneurysm model using a configuration similar to regular PIV. This was done by using a two cavity high speed laser, one double frame high speed camera and normal visualization. The two in-plane velocity components were obtained from the holograms reconstructed intensity distribution using a PIV analysis. The out-of plane component was obtained from the reconstructed phase differences using an interferometric method. Due to the laser short coherence length, a portable and compact system has been built in order to be able to the measure larger fluid areas.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 体内进行显微粒子成像测速方法测量鸟禽胚胎心脏血浆的流动状态
文献贡献者
相关方案
当前位置: 欧兰科技 方案 约束流体3C-2D 速度场的数字高速全息测量
