方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
To understand and optimize the combustion processes in new types of internal combustion engines, like gasoline direct-injection engines, non-intrusive laser-based diagnostics methods have proven to be versatile and important tools to measure combustion characteristics. Most engine developers already rely on optical methods in the development of new engines. To guarantee accurate and reliable results of optical measurements it is necessary to carefully evaluate and characterize these techniques under realistic conditions. In this work a variety of laser-based diagnostics techniques, mostly based on the tracer- LIF principle, have been evaluated for their applicability and limitations and have been applied to different spray systems – reaching from single droplets, over model sprays to fuel sprays in a firing test engine. The tracer-laser-induced-fluorescence (LIF) method is based on doping the fuel with a fluorescent substance whose fluorescence characteristics are used to measure various physical properties of the spray, such as temperature, droplet size, or droplet velocity. From these properties information about heat and mass-transfer mechanisms in the spray can be gained. However, the characteristics of the used tracers must be known in detail in order to guarantee useful and comparable results. Therefore, in this work various tracers were characterized in terms of their evaporation and temperaturedependent properties. The tracers Atto 680, Rhodamine 800 and Rhodamine B have further been tested for their applicability to realistic fuels.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
