方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Multiphase flows in process industry- project (ProMoni) was a by Tekes and Finnish industry funded three year research project. Five Finnish universities and research units were working in the project in different applications of multiphase flows. All the results are reported in the projects final report1. The aim of this report is to give detailed insight to the work which was made by TUT:s Experimental fluid dynamics group. In the project were developed methods for dispersed phase characterization, for turbulence measurements in multiphase flows and for turbulence characterization. Digital Imaging and Particle Image Velocimetry were the used measurement methods. In institute of Energy and Process Engineering at TUT has been developed Experimental Fluid Mechanics knowledge based on optical and digital imaging measurement methods. The work has been continued several years with support of TEKES and various industrial partners. At this ProMoni-project has been reached a level, which enables research of new key tasks in multiphase fluid mechanics. The project has enabled the research of interaction of dispersed phase and turbulence and this leads to many new inventions industrial applications. This is the main motivation to publish this separate report.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
