方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
High-speed electrostatic rotary bells are widely used in the automotive industry as they provide high quality paint films with better transfer efficiency compared to air-atomizing guns. However, due to its highly turbulent spray pattern, transfer efficiency is still not ideal, i.e. some portion of paint will not reach intended target surfaces and becomes overspray. Numerical simulation of the electrostatic spraying process provides a tool to model this process as well as a way to optimize transfer efficiency. Currently, the state-of-the-art simulation model can simulate the flying trajectories of paint droplets from the edge of the rotating bell cup to the target surfaces. It requires some input information to start the simulation. The input information includes paint droplet size, velocity, and charge-to-mass ratio. Due to its large number of droplets, distributions based on droplet diameters are used to represent the entire droplet population. This paper describes experimental and mathematical methods to measure and calculate paint droplet size, velocity, and charge-to-mass ratio distributions. The resulting information can then be organized and used as the input data files for Electrostatic spray painting simulation.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
