方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
In the present work the process of a transient fuel injection in a constant high-pressure atmosphere is investigated experimentally. As fuel, dimethyl ether (DME) is used. The goal is to receive new information about the charac-teristics referring to the droplet size, the droplet velocity and the droplet shape in the jet. The high-pressure chamber has a constant pressure of 2 MPa and the fuel spray is injected with a pressure of 6 MPa, 7 MPa and 8 MPa. The spray is analysed by a Shadow-Sizing-technique and digital image analysis with temporal and spatial resolution, which even allows investigating non-spherical droplets. The correlations of d velocity and droplet shape are presented as Joint Probability Density Functions (JPDF). The conclusion of the investigation shows that little increase of the injection pressure has a remarkable effect on the droplet size. Furthermore, the centricity is widely influenced by the injection pressure. With lower injection pressure the droplet velocity decreases. Moreover, the droplets mean diameter shows a significant decrease with increasing time after the injection
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
