方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Active flow control earns growing interest for manufacturers of large transport aircraft because of the constant need to improve these aircraft in terms of less fuel consumption, higher efficiency, steep approaches and departures and less weight. Flow control devices that are based on fluidic actuators, e.g. vortex generator jets (VGJs), have shown a promising potential to influence separating boundary layers and keep them attached (e.g. Godard & Stanislas (2006a‐c); Johari. & Rixon (2003); Johnston & Nishi (1990); Mc Manus et al. (1996); Ortmanns et al. (2008a); Pauley & Eaton (1988); Scholz et al. (2006)). For an efficient operation such devices need to be optimized regarding their ability to influence the flow. However, optimization turns out to be very challenging because of the vast parameter space and the lack of an adequate “figure of merit”. The proposed contribution will discuss the possibility to assess and optimize such devices by analyzing the velocity fields from stereoscopic PIV measurements.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
