方案下载应用领域 | 交通 |
检测样本 | 汽车电子电器 |
检测项目 | |
参考标准 | 暂无 |
The present work describes a new method which allows the spatially resolved quantitative determination of gaseous hydrocarbon densities in droplet laden flows. The technique is especially dedicated to a quantitative and linearly spatially resolved measurement of air/fuel ratio (λ-value) in direct injection Otto engines under stratified operation and by use of regular gasoline (Euro Super). The new method is based on spontaneous Raman scattering. It is applied to the investigation of the air/fuel ratio distribution inside and in the close surroundings of the spray cone of different DI-fuel injectors under stratified and homogeneous engine operation conditions. Both crank angle resolved snap shot and cyclical averaged measurements are presented. Simultaneously the planar gasoline distribution is detected by LIF of aromatic hydrocarbons which are native constituents of regular gasoline. It is shown, that the linear spatially resolved air/fuel distributions measured by means of LIF correlate well with the Raman data.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
