方案下载应用领域 | 交通 |
检测样本 | 汽车电子电器 |
检测项目 | |
参考标准 | 暂无 |
In 1897 Rudolf Diesel (1858-1913) demonstrated a new type of internal combustion (i.c.) engine in which the high compression pressure of about 35 times the atmospheric pressure led to a sufficiently high temperature to cause the auto-ignition of kerosine. Ever since diesel engines remained popular owing to their relatively high efficiencies and their ability to combust a large variety of fuels predominantly containing heavier crude oil components (i.e., longer aliphatic hydrocarbon chains). The original engines were 4-stroke engines in which one complete engine cycle takes two revolutions of the crank shaft. The latter transforms the translational energy of the piston in the cylinder into more convenient rotational energy with respect to vehicle propulsion. As schematically depicted in figure 1.1, in the first stroke the piston moves downwards in the cylinder and ambient air is taken in above the piston (inlet stroke). In the second stroke the inlet valve is closed and the piston moves upwards compressing the intake air (compression stroke). Just before the piston reaches its Top Dead Centre (TDC) fuel is sprayed in the combustion chamber and combustion takes place driving the piston downwards again in the third stroke (expansion stroke). Finally, the exhaust valve opens and the piston moves upwards again in the fourth stroke (exhaust stroke) pushing the combustion gases out of the cylinder. In later years 2- stroke diesel engines were developed in which, by using the space of the crank case below the piston as well, the work usually done in four strokes is now performed by one revolution of the crank shaft. Around 1940 the first turbo-charging diesel engines were developed in which the energy contained in the exhaust gases is used to compress the intake air in order to boost the power of the engines.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
