方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Turbulent jets have been always present in fluid-mechanic researches due to the large number of applications they have and to the presence of all the turbulence features on them. Thanks to the use of relative new non-intrusive techniques–such as PIV (Particle Image Velocimetry)-, the knowledge of turbulence in general, and turbulent jets in particular has increased. This work is focused on the assessment of both, the main characteristics of the turbulent jet and, at the same time, some significant PIV features. For that aim two experiments are proposed: -The first one, denominated “Spatial Resolution in PIV”, tries to determine the best position to place the digital camera that films the movement of the particles present in the jet, taking into account that we are interested on studying not only the microscales of the turbulent flow, but also the velocity field and the recovering of isotropy by evaluating the turbulent parameters (skewness, kurtosis, square mean derivative ratios,…). -In the second one, called “Effect of the Reynolds Number in Turbulence”, starting from the results of the first experiment, the behavior of the jet depending on the relationship between the inertia forces and the viscous ones is analyzed. To do this, three different zones along the jet and eight different Reynolds numbers are to be studied. This report is structured in four different chapters. The first one corresponds to a theoretical introduction to turbulence. In the second one the experimental setup is described after introducing the PIV measurement technique. The third one presents the results and carries out a deep analysis of them. Finally, in chapter four, the results are summarized obtaining some important conclusions and considering as well future challenges of the present work.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
