方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Reducing the deleterious effect of Vortex Induced Vibrations (VIV) in marine risers is an important task for ocean engineers; and many competing factors exist in the design of VIV suppression devices. This thesis explores the experimental minimization of the drag force and the disruption of v0l1ex formation by utilizing VIV suppression devices. Two series of tests are conducted-both utilizing separate testing designs. The first tests are the flexible cylinder experiments, detailed in Chapter 2, which determine the drag force and vibration amplitude of numerous, original testing configurations. The second series of tests are the rigid cylinder, PIV experiments, detailed in Chapter 3. These tests measure both the drag force on the cylinder and the oscillating component of the lift force, the latter of which is a good indication of v011ex formation. The Chapter 3 tests also image the test section wake-providing helpful insight into the physical process of vortex formation. In brief, this thesis presents a detailed description and results of the two series of original VIV suppression tests. Many original configurations are tested, and the results are contained herein.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
