方案下载应用领域 | 其他 |
检测样本 | 油墨 |
检测项目 | |
参考标准 | 暂无 |
Many materials, such as paints, clay suspensions, concrete or inks, are complex fluids which present non-Newtonian properties. To define their rheological properties and particularly for coarse suspensions (debris mud, sediments…), we need to develop specific devices because of the size of the particles within the fluid to reach the continuum assumption. The study of the inclined plane flows can be a solution as soon as we are able to measure the evolution of the free surface and the surface velocity during the flow. We have developed specific 3D measurements based on stereovision to extract rheological properties of two materials flowing down an inclined flow. First a shear thinning fluid (a polyoxyde ethylene solution) is used to validate the method which is then applied to a viscoplastic material (a bentonite suspension). The comparison of the results with conventional measurements using a rheometer is in good agreement.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
