方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The pressure field within the near field periphery of a small scale rotor blade is investigated by means of classical statistical analysis techniques and proper orthogonal decomposition. The signatures are acquired using a circular arc array of dynamic pressure transducers, centered on the rotor tip at a distance of 1.5 chord lengths and below the tip path plane. The rotor is set to collective pitch angles ranging from 0. to 12. and is operated at 35Hz and 25Hz rotor speeds under hover conditions. Each blade from this two bladed rotor is investigated independently in order to isolate pressure signal differences existing between the blades. The results show that while the average inter-blade signatures are relatively constant, the variance of the fluctuations possess noticeably different amplitudes. Given the scale of the rotor, these differences are attributed to the surface roughness effects. A low-dimensional analysis reveals that the first few most energetic modes produced by each blade are relatively consistent in shape and so concerns about differences between the signatures produced by each blade are contracted. Two important features about the near-field signatures are then revealed. The first is a low frequency, low wave-number type oscillation and is observed in all microphone signals positioned between the tip path plane and 75. below. The second signature however comprises a high frequency, high wave-number signature that manifests itself at shallow angles relative to the tip path plane of the rotor. The latter of these is believed to be the associated with the radiating component of the pressure field produced by interactions of the rotor blade with the tip-vortex. A low-dimensional reconstruction of the raw pressure signal illustrates how each of these signatures contribute independently to the original raw signal.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
