方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Refrigerated air curtains are used in supermarket display cases to keep warm ambient air from entering the refrigerator case. Entrainment of ambient air into the curtain by shear layer mixing contributes to both the sensible and the latent heat load on the cases. In order to reduce this entrainment, a closer look at the air curtain is undertaken here. Particle Image Velocimetry was used to examine idealized air curtains of various Reynolds and Richardson numbers. The air curtain entrainment was seen to be dominated by eddies that engulfed ambient air into the air curtain. For the isothermal (Ri=0) curtains, it was observed that the air curtain dynamics and entrainment were not sensitive to Reynolds number variation between Re=3800 and Re=8500. At low air velocities (Re=1500), the curtain was found to detach, leading to extremely high entrainment rates. Variations in Richardson number of the curtain affected the flow at the curtain inlet most dramatically, where the acceleration of gravity caused the curtain to neck inwards. The overall thermal entrainment was shown to reduce with reducing Reynolds number, implying that a reduction in air curtain entrainment could be achieved by reducing the air velocity of the curtain, as long as air curtain integrity is maintained.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
