方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The purpose of this experimental study was to analyze a two-dimensional cavitating shear layer. The global aim of this work was to improve understanding and modeling of cavitation phenomena, from a 2D turbulent shear flow to rocket engine turbopomp inducers. This 2D mixing layer flow provided us with a well documented test case to be used for comparisons between behavior with and without cavitation. Similarities and differences enabled us to characterize the effects of cavitation on flow dynamics. The experimental facility enabled us to set up a mixing layer configuration with different cavitation levels. The development of a velocity gradient was observed inside a liquid water flow using PIV–LIF (particle image velocimetry–laser induced fluorescence). Kelvin-Helmholtz instabilities developed at the interface and vaporizations and implosions of cavitating structures inside the vortices were observed. The mixing area grew linearly, showing a constant growth rate, for the range of cavitation levels studied. The spatial development of the mixing area seemed hardly to be affected by cavitation. Particularly, the self-similar behavior of the mean flow was preserved despite the presence of the vapor phase. Successive vaporizations and condensations of the fluid particles inside the turbulent area generated additional velocity fluctuations due to the strong density changes. Moreover, when cavitation developed, the Kelvin-Helmholtz vortex shape was modified, inducing a strong anisotropy (vortex distortion as ellipsoidal form) due to the vapor phase. The main results of this study clearly showed that the turbulence-cavitation relationship inside a mixing layer was not simply a change of compressibility properties of the fluid in the turbulent field, but a mutual interaction between large and small scales of the flow due to the presence of a two-phase flow.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
