方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Tomographic PIV as a full volume 3D-3C flow field measurement technique can also be applied to thin sheets used in standard PIV. Tomographic PIV and Stereo PIV are compared with experimental data from an impinging jet in water. The field of view is 60 mm x 40 mm, the light sheet thickness is varied from 8 to 55 pixel. Images have been recorded with 4 cameras to gain results from two independent Stereo PIV systems and from Tomographic PIV using 2-4 cameras. Different error sources for both techniques are quantified. It is shown that instantaneous flow fields from Tomographic PIV deviate less from each of the two stereo systems, than the two stereo systems deviate from each other. A systematic error pattern is identified for the two stereo systems, which is not present for Tomographic PIV. Thin volume Tomographic PIV allows the calculation of multiple vector planes. Two planes can be calculated even for the thinnest light sheet (8 pixel) providing the full 3x3 strain-tensor. Thicker sheets with up to twelve vector planes allow the visualization of the small vortex structures in this experiment.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
