方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The unsteady organization and the evolution of the coherent structures within the immediate wake of the sharp symmetric trailing-edge of a NACA0012 airfoil is investigated using two-component (2C) and tomographic particle image velocimetry (Tomo-PIV). The inspection of the Tomo-PIV results showed new vortical structures, introduced here as counter-hairpin vortices, evolve in the wake region to direct the turbulent mechanism towards recovery of the wake deficit. These vortical structures are topologically similar to the hairpins of a turbulent boundary layer as they appear to be Ushaped but with inverted orientation. The spanwise portion of a counter-hairpin vortex is in the vicinity of the wake centerline and the legs are inclined at an approximately 60 degree to the wake axis in the downstream direction. They partially wrap around the high speed streaks and frequently sweep the high-speed flow towards the wake centerline. A pattern recognition algorithm is applied to establish characterization based on an ensemble averaged counterhairpin vortex. The formation mechanism of the counterhairpin vortices is attributed to the shear layer produced along the wake centerline by the neighboring of a low and a high speed streak which promotes formation of spanwise vortices that form the vortex by connection to quasistreamwise vortices.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
