方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
In this work the influence of the internal flow field on the liquid film was investigated. A strategy for reliable PIV measurements inside of nozzle channels with a height of only a few hundred micrometers and at flow velocities of several m/s has been developed. These PIV measurements provided 2 dimensional snapshots of the velocity field inside the nozzle as well as velocity- and fluctuation-profiles across the channel. The development of the channel flow could be observed along the channel length at laminar and partly turbulent flow conditions. Disturbances were introduced to the flow field by inserting a wire into the channel flow. PIV measurements showed the resulting change of the nozzle flow (in the wake of the wire and without wire, respectively). The resulting effects on the free liquid film were observed using back-lit photographs and perpendicular lightsections through the film surface. In the case of the undisturbed nozzle, velocity fluctuations occurred mainly in the boundary layer and the fluctuations in main streamwise direction were dominant. The free liquid film of this nozzle was smooth at the exit and only at higher Re numbers the growth of surface waves could be observed further downstream. The nozzle with inserted wire showed a high level of velocity fluctuation in the center of the flow. Here, the fluctuations normal to the walls were of the same magnitude as the fluctuations in streamwise direction. The liquid film of this nozzle was roughened directly below the nozzle exit, even at low Re numbers. The high level fluctuations normal to the wall are assumed to play the dominant role in this process. These measurements demonstrate the influence of the internal flow field on the liquid sheet. The results of the present work agree well with recent experiments of Heukelbach and Tropea [1] and supplement the existing experimental data which for example can be used as input or validation of numerical simulations.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
