方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Simultaneous local jitter, 2-D wavefronts and accelerometer measurements were performed in the flow over a flat-window turret at Mach numbers between 0.3 and 0.4 along a centerplane with a viewing angle varying between 90 and 118 degrees. Both local and global jitter imposed on a small- and large-aperture laser beams were measured using position-sensing devices and a high-speed 2-D wavefront sensor. A linear stochastic estimation technique was applied to separate the mechanically-related component of the jitter from the aero-optical component. Spectra of aero-optical jitter for different elevation angles and speeds were calculated and useful scaling laws were proposed. It was shown that aero-optical jitter was due to the presence of both the stationary and traveling aero-optical components. Detailed analysis of the global and the local jitter spectra and the spectral cross-correlation between them at different speeds and viewing angles is presented and discussed in details. Additionally, PIV system was used to measure the flow field over the flat window, simultaneously with the aero-optical jitter measurements.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
